Re: Engine height on Pontoon.
I have a 25' pontoon with a 90hp mounted on it. While it does steer harder at higher speeds it isn't laborious. I too also had a boat with power steering and the difference is one where you could do S's int he water with one hand VS having to really grab with two hands and force it over on the pontoon. Slower turns and corrections do not require this amount of heft and could be done with one hand. if it is laborious, you then probably have a problem.
Have you tried different trim settings? Trimming it out?? My outboard is set pretty deep (thinking about moving it up a notch, but not for that reason) as well.
__________________
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not.
-Thomas Jefferson
