Re: sparkplug wires
they;re a hard thing to diagnose since they corrode from the inside out. If you dont want to change the entire wire, which you probably should anyways if havent done for a long time as you say, you can always buy new boots, which comes with new springs that attach to the plug. You just cut the old wire back, press the new spring in, spray some WD 40 on it, then slide the new boot over.
