  #1
Old September 4th, 2007, 10:19 AM
nashton nashton is offline
Default 1975 Mercury 850 bogs down when put in gear
My 850 bogs down when I put in gear.
I have to "hole shot" the motor to get the boat going.
And then I am fine.
What I mean by "hole shot" is that I rev up the engine and slam it into gear and give it full throttle and then I get going.
Otherwise, if I just put into gear and give gas it bogs down and dies.
Any ideas on the problem?
  #2
Old September 4th, 2007, 10:53 AM
Chris1956 Chris1956 is offline
Wink Re: 1975 Mercury 850 bogs down when put in gear
If you continue to "holeshot" that motor, you will not have an issue much longer. Your gears will be shot.
You likely have the carb idle mixture set too lean. Open the top carb 1/8 turn and see if acceleration (the normal way) improves. If not open the bottom carb screw 1/8 turn and try again. Repeat id necessary. If you cannot get descent acceleration, either the carbs are dirty, or they are still not adjusted correctly. Sometimes a shot of choke will allow the motor to rev up.
  #3
Old September 5th, 2007, 08:50 AM
Default Re: 1975 Mercury 850 bogs down when put in gear
Thank you! Any other thoughts out there?
  #4
Old September 5th, 2007, 09:36 AM
Motor Boater Bill Motor Boater Bill is offline
Adjust the idle mix with the motor in the water and in foward gear. Adjusting Idle mix in neutral will result in mix too lean and the symptoms you describe are typical of that condition. Once you get it to idle in gear, adjust both carbs for best idle in gear.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Motor bogs down in gear kanz Mercury & Mariner Outboards 2 September 3rd, 2007 09:05 PM
engine bogs and will not accelerate in gear JS Machine 1 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 July 12th, 2006 10:10 AM
1975 IL Six bogs out after about 2500 rpm minstral Mercury & Mariner Outboards 4 May 23rd, 2005 06:14 AM
1988 Force 125 bogs in gear yohimbo Force & Chrysler Outboards 1 August 2nd, 2003 11:02 PM
86 Mercury 90 Inline 6 bogs down in gear only in the water dawg_nail Mercury & Mariner Outboards 5 March 11th, 2003 03:44 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
