  #1
Old September 4th, 2007, 06:19 AM
law1@cwcom.net law1@cwcom.net is offline
Post Mercury 402 jumping out of gear
Hi
New to Iboats hope you can help,I have an oldish mercury (1978) 40 hp 402 out board started not driving on full power,been useing it this summer fine then last week had trouble finding neutral,and then as above.Anyway took gearbox off leg and after a bit of fun taken prop off.
How do you strip out gear assembly,
I see the casting as a internal large thread on it with internal Castellated nut do you remove this nut to expose gear train and make repair or inspection.
Have tried to tap this nut around but only Succeeded in breaking bits off the Castellation have left to soak in penertating oil I have the workshop to make spanner to remove this nut if it i am on the right approach
(I have a an orderin the post for manual but keen to get on with repairs)
  #2
Old September 4th, 2007, 09:02 AM
Laddies Laddies is offline
Default Re: Mercury 402 jumping out of gear
You have to remove the inter al nut that you speak of, in most case they come out fairly easily but in salt or corrosive water they may have to be drilled and broken to remove
  #3
Old September 4th, 2007, 09:20 AM
Thanks for that,yes I guess salt water and corroried,just to be sure the size would be about 55mm. is that the one with a castlation on it.
stuart
  #4
Old September 4th, 2007, 10:12 AM
I am not good with MM but 55 would be about 1.77" by my figures and the nut inside the gear case that retains the carrier is about 3 to 3.5 inches OD. If we are talking about the same part and you engine is a salt water engine you will have to drill a series of small holes across the nut in four places and use care when breaking the nut. If your not a experienced mechanic you might consider taking it to a good repair shop
  #5
Old September 4th, 2007, 07:47 PM
hi
think that we are on about same retaining nut,Your probably closer than my self in size measured it at 70mm od tonight,started to make a castleated spanner to remove the nut but drilling it out would be easy ,er up until the point where you building it back up.
(Is this normal practice to cut it out)
when i get nut out in one piece or bits,what do i look for in repairs or gears.
ps thanks for letting me know I am on the correct course so far been very helpfull look forward to more feed back
stuart
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Jumping out of gear. bitbull Johnson & Evinrude Outboards 3 August 15th, 2006 08:58 AM
Jumping out of Forward Gear C0Y0TE Johnson & Evinrude Outboards 4 June 26th, 2005 01:35 AM
5.5 jumping out of gear? Bunky Johnson & Evinrude Outboards 2 June 21st, 2005 09:55 AM
jumping out of gear elviswongg Johnson & Evinrude Outboards 4 October 1st, 2004 09:32 AM
Jumping Out of Gear... mccoyrl Force & Chrysler Outboards 5 March 11th, 2002 09:28 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
