  #1
Old September 4th, 2007, 01:32 AM
fishandshoot fishandshoot is offline
Question Cooling system issue with 30hp Evinrude
I recently aquired two 30 hp evinrude motors of dubious character. The first one I am working on, a 1986, has trouble consistently showing the tell-tale sign of the cooling system at work (that stream of water). When I first start it up, the stream is strong. After it warms up (after dying a couple times) it does not pee water and little or no water comes out of the two holes on the back of the engine. This is the case with both the muffs and in a tank of water. I hooked a hose up to the water tube and I am able to get a stream of water with both the thermostat installed and with it taken out (I wanted to see if there was some pressure loss through the exhaust port). The impeller is OK, not bad or not great. There is a lot of black gooey crud around the water pump when I have done my tests. I have not taken it our for a good run on the back of the boat because I don't want to row back to the dock. Does anyone have a clue what it going on?
thanks,
  #2
Old September 4th, 2007, 05:32 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: Cooling system issue with 30hp Evinrude
no pee stream no cooling, the pee stream is an indicator that the impeller is pumping. not that the thermostats are opening an cooling the motor, replace the impeller with a complete water pump kit, not just the impeller.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude cooling system query rajabatis Johnson & Evinrude Outboards 6 February 25th, 2007 12:50 PM
Evinrude 30hp 1988 idle and surge issue Roja Johnson & Evinrude Outboards 4 February 10th, 2007 10:24 PM
1968 Evinrude 6hp Cooling System DuckFan Johnson & Evinrude Outboards 2 January 4th, 2006 03:32 PM
Evinrude cooling system Sounder Non-Repair Outboard Discussions 2 January 26th, 2004 03:57 PM
Confused about cooling issue - '83 50 hp Evinrude USS Neversail Johnson & Evinrude Outboards 7 August 27th, 2003 07:19 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
