79 15 HP Evinrude outboard cuts out at high rpm
jeff193
My outboard starts up easily. It runs good at low to med rpm. As soon as I rev up it hits top speed then cuts out. If I choke it it will cut back in but cuts out again. I pump the gas ball but it has no effect and it stays hard.
If I cut back on the throttle the engine will run fine. I assume I have a fuel problem but what do I do next. Thanks , Jeff
tashasdaddy
Re: 79 15 HP Evinrude outboard cuts out at high rpm
dirty high speed jets. fuel starvation.
johnboatshane
I have the same problem, could it be the fuel pump?
a evinrude mechanic told me he thought it was the powerpack, wat u think?
