  #1
Old September 3rd, 2007, 07:13 PM
lostcountryboy lostcountryboy is offline
Default Kiekhaefer Mercury KF-5 "Super 5" Carb Help
I recently picked up a Kiekhaefer Mercury KF-5 "Super 5" from a friend and am trying to get it running. I've cleaned it up really well, changed plugs, fuel, checked for spark, cleaned the carb, cylnders are very clean inside. After cleaning the carb it still will not run. It seems to fire occasionly but not enough to run. I have a feeling my carburator adjustments are out of spec. I also think it would be a good idea to install a carb rebuild kit in it.
Anybody know where I could purchase a new or used carburater for this or a rebuild kit for the old one. I would also like a diagram of the diffrent adjustments for fuel mixture and stock settings if it's avalible. Thanks! Shawn R.
  #2
Old September 4th, 2007, 09:03 AM
tmcalavy tmcalavy is offline
Default Re: Kiekhaefer Mercury KF-5 "Super 5" Carb Help
Not to replace on that carb...you can cut your own gaskets using gasket material from an auto parts store. Biggest thing to check is that the float is floating and the needle valve/seat under is working. I am working on a Mark 7, a cousing to your super 5, and set the high speed/large needle at 3/4 turn out from lightly seated, and the slow speed/small needle 1.5 turns out from lightly seated. Started and ran on the third pull. If yours has the fuel shutoff valve on the carb instead of up on the tank, open the valve slightly instead of all the way, just so you can tell the float is working. Could also be dirty points or cracked coils...you'll have to pull the flywheel to check those.
  #3
Old September 4th, 2007, 09:18 AM
Laddies Laddies is offline
The carb gaskets are available through any Sierra dealer 18-7013
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1958 Mercury Mark 28 "Super Hurricane" Questions Jung4g Mercury & Mariner Outboards 6 August 22nd, 2007 02:02 PM
Using "Seaboard" or "Sea Board" to build an Extended Swim Platform ?? Linc33 Boat Topics and Questions (not engine topics) 11 August 14th, 2007 02:32 PM
Mercury Kf-5 "super 5" Mystery Gas Leak DDM71 Mercury & Mariner Outboards 0 June 20th, 2007 10:52 PM
1972 Johnson "Super Stinger" bds85466 Johnson & Evinrude Outboards 9 June 13th, 2007 05:41 PM
Suzuki 150 "super-six" questions TexSkeeter150 Yamaha & Suzuki Outboards 2 July 16th, 2003 10:59 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
