  #1
Old September 3rd, 2007, 12:27 PM
ges ges is offline
Default Yamaha multi-function gauge engine connector question
Searched and could not find anything similar...
Have a 1995 90 hp TLRT which I purchased the complete digital tach speedo package for.
Have the 5 page installation instructions also which should mean no problem right.
Problem is I only have 1 square connector on the motor and the instructions show 2 square connectors that you hook the 2 square plugs on the harness
which goes to the tach. Plus the one connector that I have is a 4 pin with only 2 pins being used (green wire and green/red wire) which I think is for the external oil tank, not one of the 2 needed for the harness.
Did some 1995 motors come without the square connectors or could there be a reason someone would remove them (I did not buy the motor new)?
Any help would be great since I cannot finish rigging the boat until this is resolved.
  #2
Old September 3rd, 2007, 01:30 PM
rodbolt rodbolt is offline
Default Re: Yamaha multi-function gauge engine connector question
on the engine end you will have 2 square connectors, trim is gray,black,orange and pink. oil is green and green red.
the harness that connects the engine to the guage will have the same colors.
green is for oil level indicate and the green red is for low oil indicate.
depending on the kit you may only have gotten the harness from the keyswitch to the guages.
somekits dont include the oil warning harness or the trim indicate harness.
  #3
Old September 3rd, 2007, 03:31 PM
ges ges is offline
Thanks for the reply, did some digging around and some electrical tape removal.
Then I have one of the two engine side connectors needed (green, green/red)
for the oil. I have the two gauge kit shown at the link below with everything in the picture of the kit on the link except the rigging instuctions booklet which was not in my box from the dealer.
http://www.maverickboats.com/perfbul...KitInstall.pdf
a. found three wires ( black, orange, pink/blue) together in black sleeving that
have been cut off.
b. found a gray wire that comes from a bullet connector (goes to another wire that also connects to a small black cylinder about an inch long) that has
also been cut off.
These are probably the wires that would go to the second connector if it was still there, right?
My luck, go figure so does anyone know of a source for the engine side connector and pins I need. Would probably have to buy the entire engine wiring harness to get it new or used or find someone willing to cut up a harness which is not likely since they are not cheap.
Or I can cut off the connector and use splices to connect them which I kinda hate to do since I paid so much for the gauge kit. Last resort if you think those are the wires I need.
  #4
Old September 3rd, 2007, 05:31 PM
yep, ya either need a wire harnes, an old engine that you can cut them off of or cut up the engine end of the new trim harness and hardwire it using a decent set of crimpers and heatshrink type butt connectors.
  #5
Old September 3rd, 2007, 06:29 PM
ges ges is offline
Thanks Again
Will try and find something that will work then in the meantime will go ahead
with the rigging, just didn't want to cut two big holes in the console if there
was a technical reason the multi-function gauges would not work with my motor.
Leave it to my luck that the previous owner would choose to just cut off
the factory connectors.
Was hoping that maybe the connector was the same as some import car which I could get at the local Upullit junk yard.
Looks like I maybe able to pick up just the trim cable fairly reasonable on Ebay and cut the connector off the tach end to use. Just have to wait for
some auctions to end and see if I can win one.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2001 yamaha 250 efi, Multi-function gauge and tps question . bernieb Yamaha & Suzuki Outboards 4 April 20th, 2007 04:41 AM
Yamaha Multi-Function Digital Tach question dpfundst Yamaha & Suzuki Outboards 18 June 7th, 2006 06:19 AM
Yamaha Multi-function guages jsnyder Yamaha & Suzuki Outboards 8 August 17th, 2004 05:47 AM
Yamaha Multi-Function Fuel Gauge Troubleshooting Mantee1 Yamaha & Suzuki Outboards 2 January 4th, 2004 04:18 PM
Whats the 3 functions of the yamaha dual multi function gauge? letsbarbq Yamaha & Suzuki Outboards 2 August 11th, 2002 11:02 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
