  #1
Old September 2nd, 2007, 10:03 PM
Oregon Jon's Avatar
Oregon Jon Oregon Jon is offline
Red face Starter Cable for 71 Evinrude 18
Hi again:
Finally got my project boat out on the water this weekend and everything ran great. One problem though is the starter cable on one of the motors. Where the cable plugs into the motor has been cut into, spliced and respliced many times and is to the point that it really should be replaced. Can I purchase a replacement plug and re-attach to the existing wires or do I need to replace the entire cable? Either way, where do I get it? There are no marine stores near me. I looked on iboats with no luck. Thanks in advance
  #2
Old September 3rd, 2007, 03:00 AM
F_R F_R is offline
Default Re: Starter Cable for 71 Evinrude 18
I don't have the '71 parts book, but the '72 uses cable part number 385158, listed as no longer available. You might try sea-way.com or discount-marine-parts.com
The plug doesn't come off the cable, you have to buy the whole thing.
  #3
Old September 7th, 2007, 01:24 AM
Oregon Jon's Avatar
Thanks for the info. I looked at the two sites you mentioned with little more than no luck. Checked out a few others with the same result: NLA. Does anyone know what other years would work so I can try to find a used one?
  #4
Old September 7th, 2007, 11:20 PM
hammerhandle hammerhandle is offline
If worse comes to worse you can make your own cables, i did on my 63' 18hp. Mine was a basket case and i didnt want to spend a fortune replacing the cables with the originals. I used heavy battery cables, you can get at walmart or possibly from iboats. Got a red for positive and black for negative in the lengths i needed, i think they make them to about 72" if you need that much depending on your battery location. They make the cables for either top post or side mount batteries.I put a rubber grommet in the motor housing to protect the wires going through the motor.
  #5
Old September 8th, 2007, 02:26 AM
Oregon Jon's Avatar
OK, sounds reasonable but what about the other 4 to six smaller wires? Got any pictures of what you did? I'm still curious what other year cables would fit.
  #6
Old September 9th, 2007, 10:00 AM
The motor i have has the starter switch on the motor itself . Im not sure what set-up you have.Im assuming you have it on a console in the middle of the boat. if that is the case you can either use your existing wire or buy new wire and route all of them in a protective wire loom back to the motor.I will try and get a pic , i never posted one on here so be patient till i figure it out. My starter switch has 4 wires hooked up to it. plus the 2 for the battery for atotal of 6 alltogether. just remember to take pics and draw diagrams of what wires and where they go.you may have to get some wire, connectors and crimpers if you dont have any tools. this isnt a hard job to do just takes time . ,,,,,,ps i think there is a link below to add pics i will post back later after i snap some photos.
  #7
Old September 9th, 2007, 10:08 AM
Just a thought on reading your original post. they do make quick disconnects for wires.The smaller wire disconnects can be found at most hardware or automotive stores like auto zone or advance auto. The battery cables disconnects might take some searching but they do make them. What Gauge battery wire do you have, if you can tell.??
  #8
Old September 9th, 2007, 11:13 AM
Oregon Jon's Avatar
My setup has an ignition key on the console in the middle of the boat. Probably best if I take a picture or two myself. Maybe we can learn together
  #9
Old September 9th, 2007, 12:19 PM
Jon : i sent a pm message for your email address, i boats will only allow 97kb for a jpeg file
  #10
Old September 10th, 2007, 11:36 AM
samo_ott's Avatar
samo_ott samo_ott is offline
For the 4 smaller wires you can use a standard trailer wiring disconnect plug. Real cheap and available at ant auto store.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
starter cable wire size?? Ken6645 Johnson & Evinrude Outboards 2 August 28th, 2007 11:35 AM
elvin-nissan starter cable length riverboater Honda & Tohatsu/Nissan Outboards 1 August 22nd, 2006 02:20 PM
Welding cable for starter / battery leads? imstillatwork Electrics, Electronics and Trolling Motors 5 March 30th, 2005 07:32 PM
Starter cable length ... how long can I go ? Moody Blue Electrics, Electronics and Trolling Motors 3 July 18th, 2004 09:42 AM
Neg Battery cable smoking along with the starter! firemedic19077 Johnson & Evinrude Outboards 9 March 16th, 2002 05:59 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
