  #1
Old September 1st, 2007, 03:31 PM
aussie01 aussie01 is offline
Default Avon aluminum floor board removal
I recently purchased a used Avon Supersport S4-00 (1989 , inflatable keel). The boat has nice aluminum floor panels that fit into an aluminum track. I have no idea on how to remove the floor so the boat can be deflated for storage. The boat sits on a small trailer right now, but i would like to be able to fold the boat up when necessary.
Does anybody know where i could find some info on the type on floor?
thanks!!!!
  #2
Old September 3rd, 2007, 02:45 AM
deejaycee_2000's Avatar
deejaycee_2000 deejaycee_2000 is offline
Default Re: Avon aluminum floor board removal
you first need to deflate the boat before removing the floor ......... once deflated the panels just pull out .....
__________________
__________________________
... THE MAXIMUM HORSEPOWER IS NEVER ENOUGH ...
  #3
Old September 12th, 2007, 03:07 PM
jnewtonsem jnewtonsem is offline
I have a SS 4.60. Found the easiest way to disassemble is to deflate most of the way, then from the front of the boat push the bow up until it is almost vertical. this will open up a gap between the aluminium and wood boards. Stick the blade of an oar into the gap and pry the aluminium board loose. To reassemble, you must get the aluminum bards to lock under the wooden board. Again Ive found the easiest way is to wedge the aluminum boards in as tight as you can, then run a rope under the boat where the boards lock. Using the rope, lift the boat and boards up forming an upside down V. Use an oar blade to get the aluminum boards under the wooden board and then let the boat down and fully inflate.
Go over to www.rib.net, they have a scan from an Avon manual which gives you basic instructions. Also have good instructions for repairing/gluing hypalon. Good luck
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Avon inflatable boat wood floor boards boatster Avon Boats 5 November 11th, 2006 10:53 AM
Aluminum to Stainless. Which Prop? I have all stats listed Avon Rib 50 hp....... boatster Prop Questions and Topics 8 September 30th, 2005 11:05 AM
Avon inflatable boat wood floor boards boatster Boat Restoration and Building 2 July 22nd, 2004 11:06 PM
Floor board not glassed in nightvision Boat Restoration and Building 2 April 2nd, 2004 05:27 PM
ROTTED OUT FLOOR BOARD ARRIVVEEINPOLO Boat Topics and Questions (not engine topics) 7 November 24th, 2001 06:29 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
