I purchased a 9.9 evenrude outboard and I can not get water to the engine. I put a new impeller and housing on with all new gaskets. I made sure the impeller has the little key in place. I even put the lower unit in a bucket of water and put a drill on the shaft. When I turn the drill on and watch the output hole in the impeller housing there is very little water coming out. Not enought to push up the tube to the motor. I am stumped. Put old housing back on with new impeller and same thing. Any one out there have an idea what is going on.???? wspann wspann@tampabay.rr.com
