  #1
Old August 31st, 2007, 03:48 PM
ksliger ksliger is offline
Default 97 Bayliner Capri 1950 instrument panel question
Greetings,
I just purchased a 97 Bayliner 1950 Capri and the 6 switches on the instrument panel aren't labeled. They are all on the right hand side and arranged in a column. I figured out the obvious ones like the horn, and light but could someone familiar with this model please list what each switch is for?
I assume one should be for a bilge pump but I never hear pump come on when testing the switches. Does this model come with a bilge pump?
One more thing: The ski locker hatch and swim platform are both damaged and need to be replaced. Is there a good place on the internet to get these parts?
Thanks!
Ken Sliger
  #2
Old September 1st, 2007, 12:12 PM
FusionFrank's Avatar
FusionFrank FusionFrank is offline
Default Re: 97 Bayliner Capri 1950 instrument panel question
They are from to bottom:
Horn
Accy - On mine, this is not hooked to anything, I assume it is there
to wire to what ever accy you may install
Navigation Light - (frt red / green light)
Anchor Light - White light on pole that plugs into rt rear of boat
Bilge Pump
Blower - The blower motor to remove fuel fumes from the engine
compartment prior to starting
My swim platform broke too (the ladder part snapped off) there are a couple listed on ebay from greatlakeskipper.com but not the correct one for our boat. I checked with my local bayliner dealer and they told me bayliner no longer makes that swim platform. It seems the only option is to get an aftermarket one. The holes however will not match up, so it will be neccasary to fill the old holes and drill new holes, but this will be a better swim platform and should last longer / be stronger. As for the ski locker latch, mine is not broken, so I have never looked for that. Hope this helps.
Frank
  #3
Old September 3rd, 2007, 10:42 AM
Thanks Frank!
  #4
Old September 19th, 2007, 07:50 PM
BAYLINER185's Avatar
BAYLINER185 BAYLINER185 is offline
Send a message via Yahoo to BAYLINER185
your bilge pump SHOULD be down in there under the motor!
Make sure it works if not replace it. You should be able to hear it "buzzing" if the boat is not in the water, even then in the water with an empty bildge you can here it if you listen for it other wise pour in some water in the bildge and see if you see the water pumping out the side of the boat. If not then replace the pump cause it can save your life and get you back to the dock if you start leaking for some reason!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1997 Bayliner 1950 Capri Prop? FusionFrank Bayliner Boats 1 August 2nd, 2007 12:21 AM
1986 Bayliner 19' BR Instrument panel bayliner19 Boat Topics and Questions (not engine topics) 0 August 25th, 2006 01:28 PM
Anyone tell me where to find a replacement Bow cover-88 Bayliner 1950 Capri Bry21317 Boat Topics and Questions (not engine topics) 10 May 12th, 2006 11:01 AM
Instrument Panel jmccall001 Boat Restoration and Building 2 August 7th, 2005 09:37 AM
I need body parts for '89 Bayliner capri 1950 jamiewashere256 Boat Topics and Questions (not engine topics) 1 June 18th, 2003 03:26 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
