  #1
Old August 30th, 2007, 06:55 PM
duckboat1 duckboat1 is offline
Default Evinrude Lark 40 comes out of gear
I have an older (late 60's) Evinrude Lark 40 that soundsd like the prop is slipping, but it isn't. I just rebuilt the carb, put new points, coils and plugs in it and got it running like a top and now it was running so good that it would fly out of gear at WOT. Rather than fixing the problem, I quit running it WOT. Last night while I was out I hit a 6" piece of debris and it kicked the motor up. Now when I go to take off it sounds like the prop is slipping, but it isn't. If you let off of the throttle it will reengage in gear but I can't get it over approx. 1500 - 2000 RPM's before it does it again. Does anyone know what this sounds like? Should I try to repair or use it as an anchor? Thanks.
  #2
Old August 30th, 2007, 08:13 PM
Trackbolt Trackbolt is offline
Default Re: Evinrude Lark 40 comes out of gear
My 58 Evinrude Bigtwin 35 did the same thing some years ago. Turned out to be a worn out rubber hub in the prop. The prop would spin and move the boat along at low speeds but any thing near half throttle it would slip. You could look over the back of the boat and see it spinning even as the motor was trying to run away. I replaced the prop and all was good. If you had sheared your shear key the prop would not spin at all. Hope that is all it is.
Good Luck
  #3
Old August 30th, 2007, 08:25 PM
F_R F_R is offline
You say it's a "late 60s" Lark. That would make it a Selectric shift. That what you have?
If so, the first thing to do is check the gear oil and make sure there is no water in it. Also, it uses special Evinrude "Premium Blend" oil.
Second thing to check is voltage at the green and blue wires going down to the lower unit. Should be 12V on green when in forward (key on) and 12V on blue when in reverse. Shift back and forth a whole bunch of times to make sure you get 12V every time. Check without disconnecting the knife terminals. If you don't have 12V every time, suspect the push button switch, a very troublesome unit.
Don't run it any more till you have made these two checks. You could make it worse in a hurry.
If that all checks out, check the prop hub.
If none of the above, you have trouble in the lower unit or wires going down to it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1967 Evinrude Lark VIII engine and 1967 Aerocraft Lark boat 1967 aerocraft classic Johnson & Evinrude Outboards 4 May 21st, 2009 11:55 PM
Evinrude Lark IV Slipping Out Of Gear Zebu Fellenz Johnson & Evinrude Outboards 11 July 1st, 2008 01:21 AM
57 35hp lark/big twin? frustrating in gear ian354 Johnson & Evinrude Outboards 10 June 25th, 2007 03:04 PM
1971 Evinrude 18 or 1962 Evinrude Lark IV comments Robdogg Johnson & Evinrude Outboards 1 October 31st, 2002 11:49 PM
'62 40 hp Evinrude Lark IV, smokes, wouldn't go into gear janmcf Johnson & Evinrude Outboards 9 June 26th, 2002 07:19 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
