Liberator 6
- Jul 13, 2006
- 50
All,
I used the attached flowchart and sure enough when the white/grn line was grounded and the ignition on, the coil kicked a spark and according to that, I read I need a new ignition sensor in the distributor. 87 350 Magnum is what I have. My only concern, is my ignition sensor has a large brass piece for the rotor to spin through, and this part doesn't seem to have that on there. Do I just swap the old brass piece for a new one? Or is the brass piece a seperate part?
http://www.iboats.com/Mercruiser_Ig...6529165--list_time.1186104441--view_id.270882
Thanks for all your time. You all are the only reason I haven't lit the boat on fire and pushed it down the driveway...
