Possible wiring problem
Marty L
I have a Force 125hp 1984 4 cylinder it appears to have a wiring problem can anyone help the motor runs but runs very rough it is getting fuel but it seems to be the cylinder firing sequence or an ignition wiring problem does anyone have an ignition wiring diagram.
baxtr
Re: Possible wiring problem
should fire 1234 top coil to top cylinder 2 to 2 3 to 3 4 to 4. are you getting spark to all cylinders? is this a new problem or did you just get this motor
