  #1
Old August 30th, 2007, 12:53 AM
Rod Holder Rod Holder is offline
Default 80 hp Mercury Lower Steering Pivot Slop
Hi,
I'm looking at a boat with a late 80's Mercury 80hp. While checking things out, I pulled back on the lower unit (with motor in full down position)and I could see that the lower steering pivot point is sloppy.
Is this a major job to deal with ? Any idea how many HRS a shop would charge ? I could probably do it but would like to know if there are any pain in the rear stuff that I should know about.
Any advice mucho appreciated !
RH
  #2
Old August 30th, 2007, 01:31 AM
Scaaty's Avatar
Scaaty Scaaty is offline
Default Re: 80 hp Mercury Lower Steering Pivot Slop
Quote:
Originally Posted by Rod Holder View Post
Hi,
RH
Walk away if you are not ready pull the whole motor down. My Merc Guru has a deal with a M/S to line bore just about ever old inline he finds and rebuilds, and press new bushings...they are either froze up into one piece (usually salt), or so sloppy, steering, waves. prop torgue.....uuuggghhh...all ya do is swat the wheel B+F..
..more than a slight tug and just a touch of play OK...make sure its not a busted motor mount too..common..
  #3
Old September 1st, 2007, 11:22 AM
Thanks Scatty,
I think you are referring to the tilt pivot area ?
The problem on this one is down at the lower steering pivot location. This is right next to where the shift rod "emerges" from the lower unit. It appears to be a pivot arrangement similar to a bicycle steering post setup.
Are these a real bugger to repair once saltwater corosion has caused it to become loose ?
RH
  #4
Old September 1st, 2007, 12:40 PM
Chris1956 Chris1956 is offline
Wink Re: 80 hp Mercury Lower Steering Pivot Slop
RH, The play is either in the lower yoke, the lower bushing, the lower motor mount, or some combo of all three. If you drop the LU and pull off the motor mount nuts, you may replace the motor mounts and yoke. That is a relatively easy fix. The lower bushing is a real PIA.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Bravo 3 steering slop Mischief Managed Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 16 April 22nd, 2007 09:30 PM
How do I get rid of steering slop? bamadave Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 August 11th, 2005 06:47 PM
How do I get rid of steering slop? bamadave Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 August 11th, 2005 07:27 AM
slop in steering JAL51974 Boat Topics and Questions (not engine topics) 10 August 3rd, 2005 07:53 PM
Steering slop - Motor or steering or normal? Tinkerer2 Johnson & Evinrude Outboards 2 January 4th, 2004 03:59 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
