  #1
Old August 29th, 2007, 11:52 PM
wildchildc1 wildchildc1 is offline
Default 1988 Mercury flooding itself on start
I have a 1988 115 hp Mercury outboard that is hard to start hot or cold.. Its flooding itself on startup,.. then is loaded up and has to be cleaned out and then idles and runs perfectly thereafter. What it does is.. It fires right up, dies and will contine to crank unless you hold it about 1/4 - 1/2 throttle for about 4 or 5 seconds while cranking and it starts then dies and then after about two or three times of doing that it will stay running, its all loaded up, once it clears up after a few seconds, it runs great.. No problem loading up on idle, no hesitation. I have installed 6 new spark plugs and gone through all 3 carbs and made sure everything was adjusted to factory specs. Does anyone have any ideas on what I may do to correct this problem? Thank you
  #2
Old August 30th, 2007, 03:00 PM
hkeiner's Avatar
hkeiner hkeiner is offline
Ensign
Default Re: 1988 Mercury flooding itself on start
Since you are sure you have the carb jets and floats adjusted properly, you might consider checking for a weak spark when the motor is cranking but not starting. A weak spark can cause the flooding you describe.
Is it possible that the motor is not actually flooding but is overloading on oil? If the oil injection system has a faulty check valve, the motor will be hard to start and smoke a lot at startup until the excess oil is burned off. Just a thought as this was a problem that I had on my motor previously. Here is a thread discussing that.
__________________
1996 Mercury 150HP V6 carbed outboard motor and Maxum 1900XR bowrider boat
  #3
Old September 1st, 2007, 08:39 PM
biocanuck biocanuck is offline
Have similar problem with 88 merc 90 horse 3 cyl.
Mechanic replaced switch box (power pack?) ...better...will fire...but then stalls and seems to be flooded. Return in 15 minutes...fires,stalls. Sometimes with full throttle idle it will start in a cloud of smoke and keep running. Once it's started and warmed up it will restart in a heartbeat. These mercs are awful on cold start. Too much choke...floods...not enough choke or throttle...fires once, stalls,floods. Anybody got the knack for starting these?
  #4
Old September 1st, 2007, 10:11 PM
Silvertip Silvertip is offline
Yes -- Cold Start Procedure:
1) Squeeze primer bulb until firm.
2) Raise fast idle lever about 1/3 up.
3) Turn key to RUN (not start)
4) Push key in for a count of eight (this primes the engine).
5) Now turn key to START.
6) When engine starts lower the fast idle lever to a slightly faster than normal idle.
7) If the engine tends to die off in a few seconds, give the key a quick push to give an extra shot of fuel.
If the engine does not immediately start at step 5, push in on the key while cranking for just a second or two.
There is no automatic fast idle on a carbed two stroke so the mistake people make is not using the fast idle lever. Cold starts and flooded engines is what the lever is there for. If you do flood the engine, raise the fast idle lever full up. Flooded engines need air -- this action provides it.
  #5
Old September 2nd, 2007, 03:43 PM
Talking Re: 1988 Mercury flooding itself on start
Thanks Silvertip...started up right away and continued to run using your 7 steps...great advice from the Fleet Admiral!
I think I wasn't giving it enough choke...afraid it would flood...but the more i read on this forum....seems like they don't flood that easily...but won't start if not enough choke.....much obliged!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1988 90 HP Mercury Outboard - Won't Start imported_dgordon Mercury & Mariner Outboards 6 August 12th, 2006 10:49 PM
1988 Mercury 70 hp stalls,no start henryp Mercury & Mariner Outboards 2 July 2nd, 2004 04:03 PM
1988 Sea Ray Mercury 100 HP - Won't start khondo Mercury & Mariner Outboards 1 September 2nd, 2003 06:14 AM
1988 Sea Ray Mercury 100 HP - Won't start CORRRECTION khondo Mercury & Mariner Outboards 1 September 1st, 2003 10:58 AM
1988 MERCURY 35 WILL NOT START scottym Mercury & Mariner Outboards 7 January 18th, 2003 02:00 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
