  #1
Old August 28th, 2007, 08:07 PM
evinrudexp evinrudexp is offline
Default 1988 150 Evinrude Xp Vro Stalling At Open Throttle
Hey Guys!
I have an issue with my 1988 Evinrude XP VRO that I was hoping maybe some of you here can help me on. Basically (or not so basic!), the motor runs nice in neutral and at idle when in gear. BUT as soon as I get on the throttle in gear the motor wants to stall and will die if I dont pull back on the throttle. In neutral is revs up fine, but in gear it wants to stall out. THEN, occasionally it will start to stall but then take off all of the sudden and run great at WOT before it will again loose power and want to stall.
I have replaced the plugs but no change.
I tried to pump the primer bulb but no difference.
Im not sure if its a fuel problem such as my gas tank, lines, fuel pump, or carbs). Or, if its electrical such as power packs, coils, etc?
Any ideas???
Thanks in advance
  #2
Old August 29th, 2007, 06:43 AM
emdsapmgr emdsapmgr is offline
Default Re: 1988 150 Evinrude Xp Vro Stalling At Open Throttle
Engines will run fine in neutral. Any problem will show up when under load. Spark check each plug wire to be sure you have fire on all 6.
  #3
Old August 29th, 2007, 03:51 PM
Quote:
Yes! "Engines will run fine in neutral. Any problem will show up when under load."
I will do the spark check. So it looks like an electrical problem?
Thanks for the reply!
  #4
Old August 31st, 2007, 03:23 PM
Okay so I did the spark check and I did see a think line of spark jumping the gap...however...it wasnt as strong blue as I expected. It was the same on all 6 plugs. I know there is spark because the motor runs but Im not sure if its not strong enough to support WOT.
  #5
Old August 31st, 2007, 05:10 PM
jaurora jaurora is offline
just went through this on my 88 150. The guys on here saved my butt. Here is one thing to try, in the water at WOT when it begins to drop RMP's and stall, push in the key to activate the primer. I be willing to bet that your boat will jump as if you gave it a shot of nitrous. It sounds like the same issue I had, pull the carps and clean the high speed jets along with the rest of the carbs!
  #6
Old August 31st, 2007, 06:55 PM
Quote:
Thanks for the reply...I have tried everything including activating the primer. But I definately think that a carb rebuild is worth doing.
I assume you have the 3 carbs right? How long did it take to rebuild the carbs? Any advise while doing this?
Thanks for the help
  #7
Old March 13th, 2009, 11:40 PM
azbassinjay azbassinjay is offline
I have the same engine and the same problems, did you ever get it fixed? I replaced the spark plugs, rebuilt the carbs, and replaced inline fuel filter. Took it out to the lake ran good at first then later in the day after fishing started up a little hard and then it ran and started to lose power and then shut off. I got it started again but it would verily go sometimes picking up in speed and then dropping back down. I am thinking that mine is overheating and I may need to replace the water pump and impeller. I am going to check the compression first.
  #8
Old July 7th, 2009, 05:20 PM
fattony72 fattony72 is offline
Hi
I am having the exact same problem with my 88 XP 150...I didn't know where to start..have you fixed your problem?...I started a new thread on the forum it sounds almost identical to yours...
Thanks
Tony V
  #9
Old September 22nd, 2009, 01:49 PM
brault brault is offline
i am also awaiting an answer to this, my motor takes about 5 minutes everytime i go out boatin and all of a sudden it runs perfect then is good for the rest of the day. but until then it bogs when opened up, and sometimes the motor does this weird ta-ta-ta at idle where it torques itself back and forth
  #10
Old September 22nd, 2009, 07:38 PM
jonesg jonesg is offline
Try to diagnose your engines in the logical manner..
Some simple cheap tools are all you need,
1compression guage,
2adjustable spark GAP tester
3and timing light.
compression test first.
then spark GAP test , not a spark plug test.
Use a timing light when it bogs to check for spark,
if all cylinders light up and it passes the gap test (set to 7/16th inch gap)
then its very likely fuel delivery.
__________________
I don't read private messages.
Get the genuine factory service manual.
www.outboardbooks.com
www.marineengines.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1988 60 HP Evinrude “pulsating” at above ˝ throttle MiloKnezevic Johnson & Evinrude Outboards 1 August 23rd, 2007 04:15 AM
1988 Evinrude 70hp VRO stuck on Full throttle casjoker Johnson & Evinrude Outboards 10 October 9th, 2006 11:03 AM
1988 Evinrude 120 V4 stalling at low revs Simon Jordan Johnson & Evinrude Outboards 1 August 10th, 2004 05:18 AM
1988 110 hp evinrude stalling stedfast Johnson & Evinrude Outboards 3 April 1st, 2002 04:30 PM
Evinrude 140 19?? - Engine dies when I open the throttle jstooks1 Johnson & Evinrude Outboards 1 August 19th, 2001 06:23 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
