  #1
Old August 28th, 2007, 07:33 PM
papamendy papamendy is offline
Default 1974 9.9 evinrude waterjacket gasket ????
I have been rebuilding a 1974 9.9 Evinrude. Replaced all the waterpump components....however when I went to replace the waterjacket gasket with the parts I got from the iboats parts section the waterjacket gasket...although similar dd not quite match up. Also most of one side of the old gasket was solid covering much of the water area with a few holes for water to pass through.The new one is wide open on both sides with the center stip intact to allow water to flow over the top to the other side. (please see part #18-2905 in the iboats evinrude parts section to see) This is the only water jacket gasket I can find listed for this year engine.....any ideas other than making my own out of gaskt material. Anyone else have this experience....thanks for your help.
  #2
Old August 28th, 2007, 10:02 PM
OptsyEagle OptsyEagle is offline
Default Re: 1974 9.9 evinrude waterjacket gasket ????
That gasket will work fine for you. You will probably find that your watercover has only 9 screw holes and that gasket has openings for 10, which will leave a little gasket material sticking out in the lower left side.
I think the problem is that OMC discontinued the cylinder head design for that motor and started using a design for a 1986 or 1987 that was pretty close to the same, for 1974s to 1976s. This change worked fine.
The reason I know this is that I changed my cylinder head on my 1975 9.9Hp Evinrude this year. My cylinder head came with a slightly newly designed water jacket (that takes exactly the gasket you have). The interesting thing was that when I took the old water jacket off, it had your gasket in it as well (I guess the previous owner had the same problem you are having). I always wondered why I had that extra little bit of gasket material hanging out. In any event, it never leaked water and worked just fine. I would have reused this jacket and gasket except the old water cover jacket would not have fit on the new cylinder head design.
So what I am saying then is that these new gaskets will fit the old (yours) design of water cover jackets and the new (mine) design of water cover jackets. The old gaskets (the one you took out) will only work for the old design.
I hope that helps.
  #3
Old August 29th, 2007, 08:06 AM
thanks for the input. I see what your saying and would have been able to use the new gasket....except 2 of the holes that were supposed to match were still off enough to where the bolts would not fit....close, but off enough not to work. Found another parts source which listed the part with a correct picture from the service manual. Hope this works out better. If not, gonna get out the gasket material and x-acto knife and just make a new one myself. At 1.27 its not too much of an expense. Thanks again for the info.
  #4
Old August 29th, 2007, 09:58 AM
Or the other option is to ask your dealer for the correct gasket. Yours is OMC#318917 or Sierra 18-0397. They should have it. I know mine had it a few months ago, because I needed the new design (like yours) and they kept trying to give me the one you want now. It took a while to figure out the problem and get the correct gasket.
But like you said they both were less than 2 bucks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Waterjacket will not seal NathanY Mercury & Mariner Outboards 4 December 6th, 2004 10:59 AM
Adding gasket maker to waterjacket gasket? brother chris Mercury & Mariner Outboards 0 September 7th, 2004 12:57 PM
evinrude 9.9-15hp gasket 1974-1976 herters Johnson & Evinrude Outboards 1 August 6th, 2004 06:31 AM
need a head gasket for 1974 4 hp johnson. who sells them bigbenc2 Johnson & Evinrude Outboards 5 June 6th, 2004 03:48 PM
Stainless Steel Bolts/Nuts For mounting waterjacket/sidepods plus gaskets y2j Non-Repair Outboard Discussions 30 October 9th, 2003 06:40 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
