atthelastminute
- Jul 11, 2007
- 21
Hi all,
I replaced all of my gauges earlier this year and had a problem with them shorting out. I got it all fixed somehow and they have worked on two outings. Last night I was attempting to hook up a depth sounder and they started shorting out again. Now without the depth sounder out of the equation, it still is shorting out.
Somehow I am getting voltage between the ground and the sender wires, different voltage on each one. This may be right, but doesn't seem like it is. Also, my nav light wiring doesn't turn on the lights, but does flip the needles all the way to the right. The last thing I did last night with all of the light wires removed and all of the ground wires removed, is hook up the voltmeter (worked), then the oil pressure (worked), then the fuel gauge (all three maxed out).
Obviously I have a short somewhere, but where? I really need to get this boat on the water this weekend, and don't want to spend another weekend working on it.
Any ideas?
Any ideas?
