Re: Did a balance test; #2 is dead but has great compression...but water coming out e
Thanks 12footer for the input...problem is that the #2 has enough spark to set you on your butt! Seems the cylinder is "washed-out"; just can't figure where the water is coming from...it actually seems the water is compressing and causing vapor-like smoke.
Woah! Quite a different matter. It's normal for water to exit with the exhast -- but water in a cylinder is bad news. Carefully pull the head, so that you can inspect the gasket for signs of blow-by, and the head for cracks. Also pull the manifold, as I suspect this is where the problem is. The manifold is where heat from the head is exchanged,and I'll wager there is a problem with the gasket, manifold/crankcase mating surfaces. When you remove it (a tough, thankless job, BTW), you'll notice seperate water and exhaust channeling.
Look for discoloration on the mating surfaces after you have inspected the gasket and it's surface for discoloration, indicating a leak.
If the gaskets, mating surfaces and head appear to have been ok, you may have a crack in the cylinder wall, or the block under the manifold. The cylinder walls aren't very likely to be cracked, given the equal and high compression numbers.
