  #1
Old August 26th, 2007, 07:45 PM
pamlicobeach pamlicobeach is offline
Post 115 HP Evinrude Flywheel Removal
I have a 1990 115 HP V-4 that I need to pull the flywheel from. What's the best technique to hold the flywheel while removing the nut and then pull the flywheel?
  #2
Old August 26th, 2007, 07:52 PM
ezeke ezeke is offline
Default Re: 115 HP Evinrude Flywheel Removal
edit
  #3
Old August 26th, 2007, 07:57 PM
F_R F_R is offline
If you use an impact wrench to take it off, you still need some sort of a flywheel holder to hold it to properly torque the nut when reinstalling. Don't think you can get by without using a torque wrench. Tons of motors have been ruined that way.
  #4
Old August 26th, 2007, 11:06 PM
miket miket is offline
I just removed my flywheel from a 1998
Johnson 115.
Used a flat Bar placing the back of the 45 degree
angle against the timer mark and the end in the
teeth of flywheel. Get a 2-3 foot piece of pipe and use
to extend breaker bar. Some one holds the flat bar
while you use the extended breaker bar.
Mike
  #5
Old August 27th, 2007, 12:11 AM
Evinrude Boater's Avatar
Evinrude Boater Evinrude Boater is offline
Master Chief Petty Officer
I used vise-grips to hold the flywheel. Sounds terrible but it worked without slipping.
  #6
Old August 27th, 2007, 10:12 PM
Does anyone know the thread spec on the three holes in the flywheel for the puller. They don't match anything in my puller kit. I am not sure if they are partially stripped or not.
  #7
Old August 27th, 2007, 10:23 PM
HighTrim's Avatar
HighTrim HighTrim is offline
Grade-8 bolts will work. Don't attempt it with the grade 5 bolts usually provided. Don't pull on the outer diameter of the flywheel when your are removing it. Be sure the flywheel and crankshaft tapers are clean and dry and use a torque wrench to tighten the nut to 100-105 ft lbs when you are done. Just thinking you tightened it enough with a regular wrench would be a fatal mistake.
__________________
Chris
  #8
Old August 27th, 2007, 10:25 PM
What's the diameter and thread pitch on those bolts. I think mine may be partially stripped, I'd like to clean them up with a tap before proceeding.
  #9
Old August 27th, 2007, 11:51 PM
DHPMARINE DHPMARINE is offline
5/16 fine fhread
DHP
  #10
Old August 28th, 2007, 12:14 AM
Would some anti-seize compound on the mating surfaces hurt when putting the flywheel back on?
  #11
Old August 28th, 2007, 12:18 AM
iwombat's Avatar
iwombat iwombat is offline
You really want clean & dry mating surfaces. Anti-seize isn't necessary - it's supposed to go on tight.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
evinrude 200hp flywheel removal problem dusky Johnson & Evinrude Outboards 12 October 24th, 2006 09:03 PM
1979 Evinrude 140 flywheel removal ......... ? Theoutdoorsman Johnson & Evinrude Outboards 7 July 4th, 2006 04:28 PM
1968 evinrude flywheel removal tomasking Johnson & Evinrude Outboards 9 July 11th, 2005 06:19 AM
1968 evinrude flywheel removal baddawg Johnson & Evinrude Outboards 5 August 8th, 2002 06:09 PM
Flywheel removal of 40hp 1963 Evinrude fitz122 Johnson & Evinrude Outboards 1 July 7th, 2002 06:02 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
