Hard time finding the right part... 1987 115hp Mercury
hokiepoq
I need to change the water pump, at least the impeller. It's long overdue. I've look around and can't seem to match the serial number of my motor to any of the available water pump kits listed. The serial number of the engine is B182522, but all the serial numbers I find on-line for 115hp Mercurys start with numbers. Any suggestions on how I can find out which is the right kit to get?
Laddies
Banned
Re: Hard time finding the right part... 1987 115hp Mercury
The inline6 115s all use the same upper w/pump kit. Imp= 47-89984 or 18-3017, upper pump kit=46-96148A5 or 18-3317
hokiepoq
Thanks, I just ordered it. Now I'm hoping there's no trick to replacing it. Fortunately I do have the manual.
Hope I can ding in. I am also having trouble realizing what pump/Impeller I need for my mercury. IT's a 1990 115 HP 2-stoke 4cylinder outboard. The serial number is oc234476.
Hope you can help.
I am looking around and I can't distinguish between the 18-3214 or the 18-3214d. Is there a difference?
Seems like a lot of these motors used the same style impeller and water pump housing.
I have the manual...and it also doesn't include the correct part number for the impeller or a replacement kit.
Any help would be greatly appreciated.
Chad.
