  #1
Old August 25th, 2007, 01:59 PM
abrazzel abrazzel is offline
Default 1998 Evinrude 150 Intuder stalls when shifting into gear
My 1998 Evinrude 150 Intruder has all of a sudden started stalling when I shift into forward or reverse. It doesn't do it all the time. It always cranks right up and idles perfect. In neutral I can rev it as high as I please, but as soon as I shift into gear it goes dead. From there it'll crank right up again, but do the same thing when I try to shift again. I can play with it back and forth and eventually get it to pick up, and it'll run great then. It's pretty random as to when it does it. It seems to be after I've run for a while and then stop and sit for an hour or more. It doesn't do it when I first crank it up for the day (after sitting all night/several nights); and it doesn't do it if you run it, kill it, and crank it right back up. I've tried pumping the bulb when it does it and that doesn't help. I called a repair shop and they said a new type of fuel was being sold to the US now and that it was designed for fuel injected motors and that it would cuase a carburated motor to do this during hot weather. He said there is nothing I can do about it and that it would do it from now on - at least in hot weather. I don't know that I believe this because most everything else I own (ATV, lawnmower, weedeater,......) has a carburator and they aren't stalling under load.
  #2
Old August 25th, 2007, 03:16 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 1998 Evinrude 150 Intuder stalls when shifting into gear
you probably are getting a dirty carb, cutting the idle fuel flow. your idle rpms in gear should be 650-750 with the motor in the water, and in gear. adjust your idle speed. and rebuild your carb over the winter.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old August 28th, 2007, 09:01 PM
RPMs are good idling and in gear. I did try choking (pushing in the key) this weekend when it started stalling, and it seemed to work the couple of times that it decided to act weird. It just seems strange that it idles perfect and even revs good in neutral. It is sort of a pain to shift with one hand and press and hold the key in with the other hand while keeping the wheel straight with knees to get going. Not a safe way to try to get on plane. Your advice to rebuild the carbs this winter may well be taken. Thanks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude 6 HP 1973 Shifting out of Gear DougRaider Johnson & Evinrude Outboards 3 August 30th, 2009 11:50 PM
60hp 1987 evinrude stalls at low rpm & when shifting in gear fab Johnson & Evinrude Outboards 7 May 23rd, 2008 01:12 PM
1998 DT150 gear shifting drama craw Yamaha & Suzuki Outboards 2 June 1st, 2006 09:57 PM
Evinrude 135 stalls when trying to put in gear 76chieftain Johnson & Evinrude Outboards 1 June 14th, 2004 07:20 PM
65 hp evinrude won't rev up and stalls when put into gear nick1981 Johnson & Evinrude Outboards 1 July 3rd, 2002 05:03 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
