  #1
Old August 24th, 2007, 11:44 PM
Tstates Tstates is offline
Default 1973 9.5hp evinrude motor won't start
I have a 1973 9.5hp evinrude outboard that won't start. I got it started yesterday by cleaning out the carb. Took it down to the river today and it started right up, headed out then just died. Now it won't start again. I took the carb apart and made sure it was getting fuel and seems to be getting plenty. Not sure why it would just die after a few minutes of use and now won't even begin to turn over. Any suggestions?
  #2
Old August 24th, 2007, 11:56 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Default Re: 1973 9.5hp evinrude motor won't start
What is the compression reading of both cylinders?
With the spark plugs removed, will the spark jump a 1/4" gap with a strong blue lightning like flame.... a real SNAP!?
Note: You need to have a 1/4" gap set up. Simply using the spark plugs is a waste of time.
  #3
Old August 25th, 2007, 05:50 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
here's more from Joe
http://forums.iboats.com/showthread.php?t=167352
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #4
Old August 25th, 2007, 04:35 PM
When I cleaned out the carb I didn't screw the "lean/rich" pin all the way in and it looks like it was getting to much gas. It now starts, but I can't push the choke in without it dying.
  #5
Old August 25th, 2007, 05:12 PM
Joe Reeves's Avatar
That sounds like you've overlooked something within the carburetor.
(Carburetor Adjustment - Single S/S Adjustable Needle Valve)
(J. Reeves)
Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.
Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.
Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
Note: As a final double check setting of the slow speed valve(s), if the engine has more than one carburetor, do not attempt to gradually adjust all of the valves/carburetors at the same time. Do one at a time until you hit the above response (die out or spit back), then go on to the next valve/carburetor. It may be necessary to back out "all" of the slow speed adjustable needle valves 1/8 turn before doing this final adjustment due to the fact that one of the valves might be initially set ever so slightly lean.
When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
http://stores.ebay.com/Evinrude-John...tc?refid=store
  #6
Old August 25th, 2007, 07:47 PM
The compression reading on the top cylinder is 60 and the bottom is 70. What should they be?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
40 HP 1973 Evinrude wont start reilley Johnson & Evinrude Outboards 8 May 25th, 2007 08:28 AM
1973 115 hp Evinrude won't start bass-fishing-muther Johnson & Evinrude Outboards 6 June 13th, 2003 09:09 AM
1973 Evinrude 85 hp won't start?????? Magicman5269 Johnson & Evinrude Outboards 8 May 21st, 2003 08:39 AM
1973 Evinrude Starflite won't start Magicman5269 Johnson & Evinrude Outboards 3 March 14th, 2003 03:20 AM
1973 6 HP Evinrude Will Not Start loopit Johnson & Evinrude Outboards 7 April 21st, 2002 03:55 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
