  #1
Old August 24th, 2007, 05:12 PM
Kar_Man Kar_Man is offline
Default 81 Mercury 115 lost power this season
I'm new to boating, but somewhat experienced with cars. A couple years ago I bought a 17' boat with a 115 merc with only 630 hours on it. I bought it in mid-fall and I let it sit over the winter without doing much to it, then ran it a bunch last summer. I was probably out in it twice a week for wakeboarding and it was great. I had a 15 pitch prop to keep the revs up during wakeboarding ~23 mph and the performance was crisp, it shot out of the hole with 3 people in the boat and a boarder on the back and with 2 guys in it, would do 45mph. It has single barrel carbs with the distributorless thunderbolt ignition (2 switchboxes).
It has always had trouble idling, I usually start it in neutral with throttle, pull it back quickly to engage the forward gear and then quickly forward to get it some throttle before it dies. This season that problem is still there. Also, when a boarder falls and I back off to 1/2 throttle, the engine usually wants to die. It usually catches itself if I back off the throttle all the way (fuel delivery/float level issue?)
At the end of last year I attempted winterizing it but spraying storage seal into it as it shut down and then put some into the combustion chambers by pulling the plugs, I also did the leg oil. This year, it has been running with less power. It used to do 45 mph with the torquer prop, but now it can only get to 40 at best and it takes much longer to plane unless it's trimmed just right.
Things I am contemplating:
- de-carb? Would a carboned engine have reduced performance? I think that's an obvious answer... but just to confirm
- timing sync. I have never done this, but I didn't think it would work itself out of sync over the winter.
- Should the impeller be replaced? The tattle-tale shoots out... not super forcefully at idle, but it's also not a trickle - it's definitely a continuous stream.
- I did a compression test and 1-5 were all within 5 lbs, I couldn't get the gauge into #6... BUT I did an idle test where I pulled each plug wire one-by-one and the engine lowered it's speed everytime, so #6 is firing.. just not sure of the compression though.
- When I had them out, the plugs looked ok, but they're center fire ones and I'm not totally sure what I was looking for. They were wet, if that means anything, but not discolored like they were carboned up.
- I'm considering pulling the fuel pump to look at it, as I've read that pin hole leaks can cause wet fouling and stalling at idle speeds (which is what I have) and then stalling at 1/2 throttle after running at full throttle issue makes me think that maybe the pump isn't delivering enough gas.
- just recently I did the primer bulb/visible fuel line from transom to the motor and put hose clamps on all of the fuel lines on the tank side of the pump under the engine cover. Previously the lines were held on with zap straps... but that didn't help at all, no effect there.
It pulls smooth, it's just low on power compared to last year and I'm scared I've wrecked something... but I don't know what would cause this. I could start throwing fuel pumps, carb rebuilds
Thanks in advance! I have already got a ton of information from these forums, I appreciate everyone's input.
  #2
Old August 24th, 2007, 11:15 PM
Plainsman's Avatar
Plainsman Plainsman is offline
Default Re: 81 Mercury 115 lost power this season
Welcome to iboats!!!
To see if it's the fuel pump, try priming the bulb and see if that helps.
Plugs should be a bit wet and tanned looking.
__________________
Rest in Peace Spinner
1978 SSV-176 Glastron with a 1976 115 hp model 1150 , 1972 Mercury115 hp
Your friend,your partner, your defender,your dog.You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion....by E.F. Henry
I am NOT a mechanic, but I did stay at a Holiday Inn Express
  #3
Old August 25th, 2007, 05:15 PM
OldMercsRule's Avatar
OldMercsRule OldMercsRule is online now
My son also has an 1981 inline 115 that I'm now gettin' all the bugs out of! (Too bad we don't have the 1982 115s that were the same as the 1981 140s)!!
It would be nice to know the compression of #6 to know fer sure. One bad hole could cause the loss of power problem yer havin'. They make testers that will fit the hole with a flexable line to the gauge, (I have one).
I don't think it is a good idea to pull the plugwires when running on those girls, (not positive about my potentially irrational fear of the Merc electronics), n' I only have one functional brain cell. Try an automotive spark tester instead. Ya never know when ya strain the electronics enough ta cause another failure especially on those six coil motors. (Most of my inlines are earlier ones with distributors, which I prefer.)
The decarb could solve yer problem. My son's motor starts, idles n' runs fairly good, but does not have the same snap outa the hole me other inlines do. Hope I don't have ta rebuild the carbs.
Try a decarb where ya spray it in the carbs n' let it sit fer a few days n' then fire it up n' run it fairly hard fer 30 minutes or so. N' maybe some Seafoam with some fresh mid grade, (89 octane), n' without alcohol if possible.
Good luck! JR
__________________
A proud n' rare Independent Cornservative from the Seattle Metro area, who runs the finest old black boat anchors money can buy!
  #4
Old August 27th, 2007, 01:03 AM
thanks guys... I took a look at it today and when I tried the link & sync procedure, I noticed that the primary pickup wasn't bottoming out and that the advance linkage wasn't really connected to the throttle. It's connect with a sprint right at the top of the shaft/assembly and the spring had fallen off, so I don't think the advance was working, which would definitely explain some of the lost power.
The plugs were carboned up a bit too, so I cleaned them off. I will put new ones in and do a de-carb later on.
Thanks everyone.
  #5
Old August 27th, 2007, 07:01 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
do the decarb with the old plugs, it is hard on plugs, and recommended to replace them after a decarb.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #6
Old August 27th, 2007, 01:47 PM
ok, thanks for the heads up.
how often should the impeller be replaced? the local shop says every year, but my book says every 50-60 hours of use.
like I said, the tattle tale isn't very strong, but I don't know when it was done last.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
lost all power james28144 Johnson & Evinrude Outboards 4 June 22nd, 2007 09:05 AM
lost power caper_45ca Johnson & Evinrude Outboards 5 July 5th, 2006 02:14 PM
1992 C115 Yamaha Power Trim Click & Lost Power to Key switch/trim LA3 Yamaha & Suzuki Outboards 2 July 4th, 2006 06:18 AM
"Official" Lost Season 2 Discussion Thread - Avoid this if you haven't eeboater Dockside Chat 93 November 17th, 2005 03:11 PM
Lost Power AAK Johnson & Evinrude Outboards 3 March 28th, 2004 06:05 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
