I recently purchased this 1985 Hydra-sport for $1500. The motor will only start using starting fluid after which is runs very well. It only runs water out of the pee hole at a high idle and the water is like what comes out of the hot water faucet at home. At low idle there is no water at all coming out but steam comes out. We didn't run it but about 2-3 min. I just wanted to make sure the motor did run. I am replacing the impeller on the lower unit, gear lube. Question; What do you all recommend doing about the starting problem? This is my first boat and motor and I certainly don't want to be stranded. It has a #50 Minnkota powerdrive also w/ a eagle fish/depthfinder. They had the cranking and trolling battery's wired together so I separated them. New lights and wiring on the trailer now. Any thoughts will be appreciated.
