Lost voltage to ignition switch
dnyhuf
1992 Johnson 200 GT ........... After running some test procedures on charging system, I lost voltage to key switch. Seems that when I replaced the cover on power pack I pinched a wire(yellow/red stripe). Can someone tell me what this wire is, as I can not locate it on schematic. Is this the culprit?
Silvertip
Re: Lost voltage to ignition switch
You blew the fuse at the engine. There should be a fuse holder with a 20A fuse in it located under the engine cowl.
