I have a 1974 15HP model 15404S, serial number 0006557 that shuts off when hot. After the unit cools for 3-5 minutes I can restart it and it will continue to run if I do not run over 3/4 throttle. I finally decided to pop the flywheel off and see what is wrong. It appears that this motor only has a driver coil, part #0763784 - according to the schematic for this model on ishopmarine.com website:
http://www.ishopmarine.com/ishop/js...37&path=BMC~A0000021~M0011581~M0011613~M00116
It does not have a "stator assembly", part # 20, #0581387, that I see in the drawing. I have owned this motor for 25 years and have never had a problem with it. This is the first time I've had to remove the flywheel. Any ideas or advice would certainly be appreciated.
Stuart
Stuart
