1998 ocean pro evenrude-200hp
charles conlin
seem to be getting air in fuel line idle is fine but unless i have someone pump ball @ high speed 34 kt. engine will die out changed 1 fuel line,but the standard 10 ft line was 5 ft to short engine is on a 1998 23 ft wellcraft cabin crusier can anyone out there help me out. got it runnin great to day but for how long,34kt @5000 against the wind.has anyone had this problem and can ya please help me out im a newbie:confused:
Chris1956
Re: 1998 ocean pro evenrude-200hp
First, Buy a piece of fuel line long enough to go from primer bulb to fuel tank in one piece, install it and clamp it securly on both ends. Second, remove fuel pickup from tank and make sure screen is clean and remove anti-siphon valve. Retest.
If things do not approve, check all fuel line connections for leaks. Finally rebuild fuel pump.
