  #1
Old August 22nd, 2007, 04:34 PM
tedfoster tedfoster is offline
Default Can't Change Impeller On Evinrude..help!!
I HAVE A 40hp EvinrudeTE40FLENM that I am trying to change the impeller and I ran into trouble. ... I removed all the bolts (5) and the lower unit dropped down a bit but wouldn't drop on down. .. It's lose and will move up and down easily and go "CLUNK CLUNK CLUNK". ... Something is holding the darned thing from coming off. .... Can anyone help me. ..... THANKS!!. .... ted
  #2
Old August 22nd, 2007, 04:39 PM
da_ardvark da_ardvark is offline
Default Re: Can't Change Impeller On Evinrude..help!!
You have failed to disconnect the shift rod. It runs from the lower unit to just under the power head. There will be some fastener there under the lower carb. Disconnect. DO NOT TURN THE ROD. This is a set length and you'll mess things up if you turn it. Look at the orientation and put it back the same way
  #3
Old March 10th, 2009, 12:56 AM
Pizazz Pizazz is offline
Send a message via Yahoo to Pizazz
I am having the same problem, I have 25 hp 1973, I cant get the damn thing down, either I feel like getting out the heavy artillery.
  #4
Old March 10th, 2009, 12:59 AM
PmDavis300 PmDavis300 is offline
definatly the shift rod if you havnt already released it. also, check if you have, you may have missed a bolt on the lower unit, i did that the other day.
  #5
Old March 10th, 2009, 05:04 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Pizazz, you should have started your own thread.
there is a plate on the side of the leg. remove it, then remove the bottom bolt on the connector.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #6
Old March 10th, 2009, 05:09 AM
old post, i you have questions open you own thread.
__________________
FLORIDA GATORS
TEBOW Country
Closed Thread
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Impeller change 77 15hp Evinrude kodiak50 Johnson & Evinrude Outboards 1 July 29th, 2006 08:43 PM
88 evinrude 70 horse impeller change Greg Clark Johnson & Evinrude Outboards 1 July 8th, 2005 10:41 AM
how to change impeller 1998 evinrude 115 myliquidassets Johnson & Evinrude Outboards 4 June 4th, 2005 12:17 PM
How to change impeller evinrude 115 hp 1998 myliquidassets Johnson & Evinrude Outboards 2 June 4th, 2005 09:33 AM
1973 Evinrude 6hp impeller change mdeanbram Johnson & Evinrude Outboards 2 February 6th, 2002 07:55 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
