  #1
Old August 22nd, 2007, 11:42 AM
outboardnut outboardnut is offline
Default 1970 40 HP Mercury Stator wiring routing
I'm in a pickle on this one. I have no idea on the color coding of the wires coming out of the stator. Is there any way to guess which wire is what without it?
click on thumbnails to enlarge
  #2
Old August 22nd, 2007, 01:58 PM
Laddies Laddies is offline
Default Re: 1970 40 HP Mercury Stator wiring routing
I don't want to come off like a jerk but I am suprized that there is a 400 out there, they were the first 2 cyl with CD ign and worked as poorly. Before you get to far down the repair road ome needs to tell you that parts for that engine are scarce and expencive. That said if the wires are already removed or broken, the only way i think you can iron out the problem is with a OHM meter and cking the ohms, it's gone to take some time but anyway here are the wiring specs. good luck
  #3
Old August 22nd, 2007, 06:50 PM
You're going to have to get meaner than that if you want to be rude. Everything I own is junk so I'm used to it,LOL!
Thanks SO MUCH for the specs. I have both a Clymer and a Seloc manual for this motor and it doensn't even touch on the info you just provided. Thank you again!
I was able to locate the two most important wires coiming from the stator.
Wire #1 read 110 ohms and wire #2 2200 ohms. So I hooked those up as the corresponding low and high speed wires. Wires 3,4, and 5 read up around 10-17 M ohms so I think I these can just be left unhooked?
The trigger tested out good, 36 ohms.
Coil tested out bad
Switch box tests out bad bad bad. Infinate resistance between blue or white and orange(test 1 and 2). Orange to ground tested out bad too so I didn't go any further.
I'm currently exploring my optinos for a coil and switch box. I have half a notion to open up the switch box to take a peak inside. Maybe it just has a corroded connection.....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Can I hot wire and bypass stator? 1970 40 HP Merc weak spark outboardnut Mercury & Mariner Outboards 4 August 28th, 2007 08:51 AM
1970 60 HP stator jolietjake Johnson & Evinrude Outboards 7 January 22nd, 2005 02:57 AM
1970 mercury 500 thunderbolt wiring ? bill cook Mercury & Mariner Outboards 10 April 8th, 2003 05:14 PM
Need Wiring diagram/schematics and hose routing info CollisionManager Non-Repair Outboard Discussions 4 June 21st, 2002 06:47 AM
Wiring Diagram/Schematic and hose routing needed CollisionManager Boat Topics and Questions (not engine topics) 1 June 20th, 2002 09:47 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
