  #1
Old August 22nd, 2007, 12:32 AM
Evinrude Boater's Avatar
Evinrude Boater Evinrude Boater is offline
Master Chief Petty Officer
Default 1960 Evinrude 40 HP, play in the crank
I was pulling the flywheel off with a puller and noticed the crank has a couple of millimeters of vertical play when I tried pulling the flywheel off by hand. Is that normal?
  #2
Old August 22nd, 2007, 12:35 AM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Default Re: 1960 Evinrude 40 HP, play in the crank
I have a problem with millimeters...... If you're speaking of .010 or .020, something of that nature, yes that's something you'll find in all of the engines.
  #3
Old August 22nd, 2007, 12:39 AM
Well let's say 2 mm is the play. That's 0.079". It could be as much as 0.10" or 1/16" to 1/8".
  #4
Old August 22nd, 2007, 01:35 AM
Joe Reeves's Avatar
That does sound fairly excessive. There's a tension spring affair attached to the bottom of that crankshaft that should prevent that play.
  #5
Old August 22nd, 2007, 08:33 AM
F_R F_R is offline
Well, about what Joe just said: That spring at the bottom of the crank is to keep the carbon seal up against the bottom of the lower main bearing. The seal is supposed to slide up and down on the shaft if the shaft moves up and down. It is true that the spring tends to hold the crank down, but if you lift with more force than the weight of the crank plus the rate of the spring the crank will move up.
I'm millimeter challenged too, but looking at a ruler I'd say two mm is perfectly normal.
EDIT: ok, I looked it up and 2mm = .0787". That is way more than the .011" specified in the book. But I'm sure I've seen them run with considerably more than that.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1980 9.9 Evinrude propeller shaft play RudeRunner Johnson & Evinrude Outboards 9 May 11th, 2006 11:19 AM
drive shaft play in 1997 evinrude 225 sandy151 Johnson & Evinrude Outboards 4 November 2nd, 2005 04:59 AM
evinrude 40 HP crank from '74 '75 or 76 eenhorn Boat Restoration and Building 2 May 2nd, 2005 10:26 AM
tilt tube play 1986 v6 EVINRUDE MR GIBBS Johnson & Evinrude Outboards 3 December 9th, 2002 10:24 AM
Flywheel play on Evinrude 7.5 1982 Burnsoftx Johnson & Evinrude Outboards 3 February 28th, 2002 05:20 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
