  #1
Old August 21st, 2007, 11:02 PM
Termite Termite is offline
Default New boat owner...few questions
I just picked up my first boat (grew up around them, just couldn't afford one myself until now) I have a few questions. It has a 1984 Johnson 70 horse 3 cylinder engine. It was in the water and used in the spring of 06, the engine starts but has to work at it. I changed the oil in the lower unit today...looked great, just slightly used. Picked up new plugs but have not put them in yet, and it look like I should pick up some Seafoam. Anything else I need to do before dropping it in the water for a run? Once it starts it seems to idle fine...maybe a little low.
I'm not real familiar with running boats on my own so I have a lot of questions. Here is my biggest one right now: is there a way to throttle up without going into gear? If not, is it safe to do that out of the water (with a cooling attachment and hose ofcourse)?
Thanks.
Mark
  #2
Old August 21st, 2007, 11:07 PM
HighTrim's Avatar
HighTrim HighTrim is offline
Default Re: New boat owner...few questions
If you are running your motor on "muffs" in your driveway, never take it above 1500, your motor will "run away" on you with catastrophic consequences. This is just for idle and quick testing. I believe on your motor you set your idle to 650 under load in gear. If you are unsure of the age of the impeller, that should be on your to do list. It is a cheap part, but if it fails, the consequences are very expensive.
__________________
Chris
  #3
Old August 21st, 2007, 11:25 PM
jtexas's Avatar
jtexas jtexas is offline
Welcome to iboats!
Do you have the control box with keyswitch and throttle/shift stick, or is your controls integrated into the boat?
Control box: there's a flat lever that lifts up, on the top edge of the control box above the keyswitch, called the "hi-idle lever" - lift it up to rev it in neutral. For starting, it should be all the way up.
Integrated controls usually have a button that you hold in when advancing the throttle, that keeps it from shifting - usually it's down at the bottom of the control stick.
Reduce the RPMs after the engine starts, leaving it up just enough to keep it running while it warms up. Heed hightrim's warning about thermal runaway.
One thing to know about your motor is, it will start and idle on two cylinders, and sound just fine doing so, until you put a load on it, then it will fail to accelerate. If it's idling low, that might be the reason. Here's how to check it:
With the engine idling on the muffs, pull then replace one spark plug wire at a time. RPM's should decrease noticeably - if they don't, then that cylinder's not making power. If that happens, remove the spark plug, reattach it to the boot, hold it against the engine block, and look for spark while somebody turns the engine over. If you don't see any spark, let us know for the next step.
If you have spark on a dead cylinder, a carb rebuild is in order. Even if all 3 are firing at idle, after a year of inactivity don't be surprised if it drops a cylinder or two when you try to accelerate - gas turns to varnish in the carbs and clogs up the hi-speed jets. If this happens, don't run it any more - whichever cylinder is not getting fuel is also not getting oil - recipe for disaster.
In fact, I'd say a carb rebuild before your first outing would be a pretty good investment of time & money.
The water pump impeller will also deform after sitting idle for a year - it might seem ok now but it won't be as effective as it was last year, and it's days are numbered - highly recommend scheduling an impeller change soon as you can get around to it.
Make sure you have fresh fuel in a clean tank, the tank vent is open and unobstructed, and the fuel line holds pressure. Do you know whether the VRO is working?
One nuther thing comes to mind - a compression test, to give you a baseline for future diagnostics.
let us know how it goes.
__________________
"It's all about the tools." -- myself
"Poets talk about 'spots of time,' but it is really fishermen who experience eternity compressed into a moment. No one can tell what a spot of time is until suddenly the whole world is a fish and the fish is gone. I shall remember that son of a b**** forever." -- N. Maclean
  #4
Old August 22nd, 2007, 09:44 PM
Thanks for the info, I'm taking Friday off to get the motor in shape and in the water on Saturday. I'll let you know how it does.
Mark
  #5
Old August 23rd, 2007, 05:46 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
replace the impeller before, so it does not run hot. make sure you have a strong pee stream even at idle. it may be peeing now on muffs, but that impeller was dry from non use, and will fail in the near future. go to engine faq, and read awakening a sleeping outboard.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
New boat owner with questions hydro556 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 23 June 21st, 2007 08:12 AM
Some questions from a newbie boat motor owner (Johnson 70 VRO) sssports Johnson & Evinrude Outboards 11 January 10th, 2007 05:39 PM
New boat owner, have many questions. Cruzomatic Boat Topics and Questions (not engine topics) 7 September 12th, 2005 05:08 PM
1977 evinrude 70 hp questions from new boat owner reddog349 Johnson & Evinrude Outboards 12 May 25th, 2005 02:25 PM
First Time Boat Owner - Questions Nacman Mercury & Mariner Outboards 7 July 26th, 2002 06:54 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
