ID this Merc
lmannyr
Master Chief Petty Officer
Ok..With the help of this forum, I was able to turn what I thought was a frozen engine. It was a frozen out drive.
What only the block sitting in the boat now, I'm will also pull it out to pull the pan and check things down below. This will be the cherry picker that will hoist the block out.
In order to figure out if I want more power or leave it as is, I need to figure what engine it is first.
The block cast id is 10066036 which indicates: it is a 350 with a 2 or 4 bolt main, Target Master/Goodwrench crate motor, 2-piece rear seal, "Hecho en Mexico"
The only place I found that had a tag with the serial number, was on the the flame arrestor cover. It was peeled and worn off.
Is there another way to figure out how much power this engine will put out? Like I put in the block, head, manifold, etc info and pops out with the expected power? This engine is on a 1983 23' Wellcraft aft cabin so I would like some decent power to push this thing. I'm thinking 300hp. I'll build it up if I need to but, I need a baseline first.
Not sure if engine is original or not.
Here are some pics...
lmannyr
Re: ID this Merc
Here is another pic.
Don S
Re: ID this Merc
On that last picture, on that plastic cover on top of the carb are some serial numbers. What is the one for the engine? If you can't read it, look at the metal tag just above the starter on the back of the block.
lmannyr
Re: ID this Merc
It's all rusted. Can it be identified by the head, carb, or anything else?
Thanks...
Don S
Re: ID this Merc
That plastic cover is NOT rusty.
lmannyr
Re: ID this Merc
Don,
Your right, the PLASTIC cover is not rusty. But I did mention it was "peeled and worn off." Sorry for the confusion. Any other ideas?
Luis
lmannyr
Re: ID this Merc
Here is a close up of the cover. It says CID is 305. That does not jive with the block cast id info of 350. Which makes me believe this is a replacement cover (likely) or a rebuilt motor.
