Re: Converting IO to OB?
I'd be willing to bet that almost all inboard transoms are tougher than almost all outboard transoms... they have to withstand a lot of force. I'll buy the part about them not being at the right height.
My understanding is that you have to align the cavitation plate on the outboard with the bottom of the hull. So the motor has to be at a certain height, and to mount it on the top of the transom you need either a certain transom height, a cut-out, or a stand-off bracket on the back of the transom.
For an IB/OB conversion, if it's a smaller boat you can use the cutout, for a larger one you'll need the bracket or something similar. You'll probably want to build a splash well if you don't use the bracket.
The important thing weight wise is that you don't want to alter the boat's center of gravity. So if you mount the motor farther back by going to an outboard, you'll want to use a lighter motor than the inboard was to maintain CG in the same place.
You can compensate by moving weight forward in other ways (batteries, fuel) but you'll alter the handling characteristics of the boat. Same problem if you add ballast forward, plus you're changing the overall boat weight.
On the bright side, using a lighter motor farther back it's possible to keep the same CG, lower the overall boat weight, and improve the boat's handling. Plus you may get a fuel savings. You'll probably pay for that in the cost of the outboard, though.
Erik
