Re: trick to remove impeller 73 85hp evinrude
If the blaster does not work, Try holding the drive shaft firmly and turning the impeller clockwise with as much force as possible.
If the shaft was not greased with Triple-Guard, there is a good chance that the dissimilar metals have fused. Use a Dremel to cut it off. Try to cut where the key is to protect the shaft as much as possible.
