Re: 1967 80 HP Evinrude Starting Problem
decribe "seemed like the battery was dead" - low voltage at the starter is one thing that keeps the bendix from rising to engage the flywheel.
97.3% of electrical problems on boats can be solved by cleaning and tightening the connections. Lots of folks never know it because the process of replacing perfectly good parts usually accomplishes the cleaning & tightening. Battery to solenoid to starter, make 'em tight-tight-tight and polish 'em till they shine. I use a dremel with a stainless steel wire brush.
if you have a multimeter you could start by measuring the voltage at the starter cable terminal end (starter disconnected) with the key turned over to "start" - if you get within half a volt of the battery open circuit voltage and the starter won't spin up fast enough to engage, starter needs rebuild.
almost forgot, that shaft shouldn't be oiled so much that oil runs down the shaft into the motor. also, use a light oil (I use 3in1), not grease, not a spray.
just found your duplicate post from this morning........what a waste of time.
__________________
"It's all about the tools." -- myself
"Poets talk about 'spots of time,' but it is really fishermen who experience eternity compressed into a moment. No one can tell what a spot of time is until suddenly the whole world is a fish and the fish is gone. I shall remember that son of a b**** forever." -- N. Maclean
Reason: just found the duplicate post from today
