  #1
Old August 20th, 2007, 01:16 AM
pontoon chief pontoon chief is offline
Default idle problems with 115 Yamaha
I am working on a 115 twostroke motor that will not idle correctly.
C115TLRY
The motor appears to have a mind of it's own.When I start it,it will idle at around 850 RPM and then for no reason it will jump to 2000 RPM and then down to 400 RPM.
It bounces around for no reason,or at least no reason that I am aware.There does not appear to be anything loose that would cause this condition.
I could better understand it if the motor would just run at the incorrect RPM,however the bouncing RPM has got me stumped.
Any idea what is wrong ?
  #2
Old August 20th, 2007, 08:52 AM
WillyBWright's Avatar
WillyBWright WillyBWright is offline
Smell our Dairy Air.
Default Re: idle problems with 115 Yamaha
Probably an ignition problem, spark cutting in and out. If you have a timing light, you can see it misfire. Just move the pick-up from cylinder to cylinder as it's running and look for steady flashing.
__________________
Hey, Have you seen? They make Really Cool life preservers nowadays.
So "Looking Dorky" is no longer an excuse for not wearing one.
  #3
Old August 21st, 2007, 09:34 AM
Ray Neudecker Ray Neudecker is offline
Very likely a fuel restriction problem. First step would be to replace the fuel pump and rebuild the carbs.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2000 Yamaha 150 Idle Problems johnsonhd Yamaha & Suzuki Outboards 0 June 25th, 2006 01:42 PM
1988 Yamaha 50 idle and top end problems walrus98 Yamaha & Suzuki Outboards 1 May 26th, 2004 11:14 AM
Yamaha VMAX Carb 150 - Idle Problems when hot Atlanta Boater Yamaha & Suzuki Outboards 7 May 19th, 2004 02:47 PM
Yamaha VMAX Carb 150 - Idle Problems when hot Atlanta Boater Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 May 17th, 2004 04:28 PM
Idle Problems on 15 hp Yamaha Arkie1 Yamaha & Suzuki Outboards 2 March 14th, 2003 04:15 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
