tysonvoorhorst
- Jul 24, 2007
- 2
We own the freedom 160 with an OMC Cobra leg. near the end of last season it developed a problem, it seemed to be jumping out of gear and then going back in while driving. We have replaced the U-joints and shafts in the outdrive. The shift cable, shift lever roller assembly.
We read some of the forums on this and found that it could be the prop or the Fly wheel. we checked both and they seem to be fine. We have also adjusted the cables in every possible direction a cable can be adjusted in. The gears in the Leg look ok. The clutch dog gear is a little rounded but doesnt seem like enough to cause a problem.
The propeller has about 1/8th of a turn of free wheel before it stops moving when it is in gear.
Any suggestions would be very much appreciated.
Sorry forgot to put a notification on the first post.
