  #1
Old August 19th, 2007, 04:03 PM
protowdriver1 protowdriver1 is offline
Default 2000 mercury 90 hp compression
I am about to purchase a boat with a 2000 mercury 90 hp ob on it and i cant seem to find what the compression should be. If anyone can help then that will be awesome. Thank you in advance.
  #2
Old August 23rd, 2007, 10:50 PM
hkeiner's Avatar
hkeiner hkeiner is offline
Ensign
Default Re: 2000 mercury 90 hp compression
The specific level of compression is less important than making sure the compression is similar on all cylinders. Compression gauges are often inaccurate as far as the specific compression level shown on the gauge but they still work fine for comparing compression between cylinders. Having said that, if your gauge shows compression over 100 psi on each cylinder and the variance between highest and lowest compression is less than 10 psi, you should be OK. Search the FAQs and other forum posts on compression checks, as it is necessary to do the compression check the right way to avoid damaging ignition components.
This is my experience anyways. Others may have additional or better suggestions.
__________________
1996 Mercury 150HP V6 carbed outboard motor and Maxum 1900XR bowrider boat
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2000 40hp mercury; No compression in top cylinder under load. Chris Cole Mercury & Mariner Outboards 35 June 7th, 2007 11:38 AM
2000 175 HP Merc EFI low Compression Coork Mercury & Mariner Outboards 3 June 8th, 2005 08:02 PM
What is compression ratio for 2000 Yamaha 60 HP? rgalvan Yamaha & Suzuki Outboards 1 July 10th, 2004 01:58 AM
2000 Mercury 225 EFI What is normal compression? darjdh1 Mercury & Mariner Outboards 1 June 20th, 2003 09:47 AM
2000 Johnson 175 Compression cjr Johnson & Evinrude Outboards 4 April 8th, 2003 06:37 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
