  #1
Old August 19th, 2007, 02:16 PM
contractorguy contractorguy is offline
Default Fins?
I'm a slolam ski/kneeboard guy and wanting to try wakeboarding. I picked up an O'Brien Buzz 140 (2004..i think) w/bindings for cheap!
It has holes for the twin tail fins (1 fin each end), but didn't come with them. The PO said they never used the fins and lost them.
I haven't had a chance to get out there and start faceplanting yet, but I'm wondering if I should try to get some fins before I try??? Size/shape???
Any help would be appreciated!
Thanks!
  #2
Old August 20th, 2007, 03:08 AM
deejaycee_2000's Avatar
deejaycee_2000 deejaycee_2000 is offline
Default Re: Fins?
most definitely ..... you will need new skegs (fins) on there, otherwise it will make it very tricky o ride the board and will slide out under you almost all the time ..... you can go to marine store to buy them .... I recommend to buy the biggest fins that will fit, as they keep the board the most stable ......
__________________
__________________________
... THE MAXIMUM HORSEPOWER IS NEVER ENOUGH ...
  #3
Old August 20th, 2007, 07:49 PM
sabastianunf's Avatar
sabastianunf sabastianunf is offline
Default Re: Fins?
I use to agree with Deejay until recently. The fins do make the board more stable and keep it from sliding out but they are a crutch. In fact you can turn a board just as well without fins - also you can do more tricks (butter slides and surface 180's) without the fins - these tricks are near impossible with large fins in. Also - to really wakeboard you need to learn how to feel an edge. The only way to get good air is to feel out and set a progressive edge. The pressure you put on the edge is what gives you the pop off the wake. If you can not feel an edge without sliding out you will never get good air. The best way to feel an edge is to ride without fins and learn to fell the edge out without sliding out.
  #4
Old August 21st, 2007, 02:49 AM
Default Re: Fins?
for a beginner skeg are needed to let them get the feel of wakeboarding .... after they can stand up with the board with no effort, you can take off the skegs if you want ...... my liquidforce wakeboard have 8 skegs and I can do any trick without any difficulty ....... so I disagree skegs do not make it impossible to do slides and surface tricks ....
__________________
  #5
Old August 21st, 2007, 08:45 AM
Default Re: Fins?
Thanks for the info...
I found a pair of cwb fins that are about 1.25" tall.
Just have to give it a go and see!
  #6
Old August 22nd, 2007, 02:46 AM
Default Re: Fins?
enjoy .....
__________________
  #7
Old September 7th, 2007, 06:13 PM
Default Re: Fins?
Quote:
No one ever said it was absolutely impossible to do surface tricks with fins. It is just near impossible for a beginner with large center fins. Yours has the fins mounted on the side which are usually smaller than center fins and have less impact on surface tricks than center fins do. anyway fin setup is based on board shape, rider ablity and preference. I think contractor guy did pretty well for himself going with smaller 1.25 fins. However, once he gets the feel for the board and starts trying tricks I think he should take them out. also - I would like to see some video of you doing an off axis blind side 5 without any difficulty.
  #8
Old September 10th, 2007, 08:29 PM
Default Re: Fins?
Last weekend finally got a chance to try. I popped right up, and was cut'n and jumpin right off (OK....more like hoppin) It's a lot easier than the slolam. What a blast!!!
I did try it once without the fins.. I could get up and could keep it under me, but it was way too loose. Tried a 180 several times. just about had it.... then I learned the backside faceplant!
  #9
Old September 10th, 2007, 10:23 PM
Default Re: Fins?
The trick to riding with out the fins is to learn to turn using the edges of the board rather than pivoting the board on the fin. To really jump you have to set a progressive edge - leaning on the edge harder as you get closer to the wake. Leaning or pressing that edge into the water as you hit the wake is what pushes you up an into the air. If the board is flat on the water as you hit the wake you will not get any pop off the wake and thus very little air if any at all. I highly reccomend buying the video series called "the book" It shows you the best way to position your board and body to get the best air - as well as showing you the basics needed to do more advanced tricks and how to drive the boat for wakeboarding. Keep riding and you will get it. Good luck.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
fins makinnat Non-Repair Outboard Discussions 4 March 20th, 2006 05:21 AM
doel fins joblo33 Non-Repair Outboard Discussions 1 July 26th, 2005 12:07 AM
Tap Fins ? Jumpy1 Boat Topics and Questions (not engine topics) 4 January 17th, 2004 04:27 AM
fins TouJays Mercury & Mariner Outboards 2 May 26th, 2003 04:57 PM
Doel Fins digimortal777 Johnson & Evinrude Outboards 5 May 5th, 2003 04:23 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
