drewmitch44
- Jun 26, 2005
- 1,749
Ok i got this motor and the previous owner has a steering cable that is bent to the right of the motor from looking at it(steering 2 pic). I have existing cabeling on my boat that i want to use(steering 4 pic). For some reason i cant get this piece out of the motor(steerint 6 and steering 4 pics). I dont know if it is stuck inside there but it is the piece that the linkage of the motor hooks up too. The cable that im trying to use is the exact same thing just the way it hooks to the dash is completely different. So i want to pull the piece out of the motor mount or clamp whatever its called (steering 2 pic)and insert my steering piece through there and hook the linkage up to that. Its the same thing i measured it with a micrometer and it will work i just cant seem to get the old one out. Is there a screw somewhere that acts as a tensioner to tighten up the rod that goes through there?? Maybee if i loosen up that i can do it. Ive tried pumping greese in there through the greese fittings and banging it with a hammer but nothing. If i hook up the linkage to whats there i cant move it left to right for nothing. Ive added pics to what im talking about. Any help would be greatly apreciated. My cable has the same big nut that will hook up to the motor and allow the rod to come out of the other side and the linkage can hook to that. It will be easy if i can get the old one out of there.
