Hi All, I have a 2000 glastron w/ 115 evinrude O/B. Here is my issue. I can launch the baot and it starts fine/runs great untill we stop and drift or go to the beach. in warm weather. When we go to leave it idles fine and runs great at low rpm untill I hit it and then it bogs. My wife pumps the primer ball to give it some gas and it go's for a bit ...then bogs/pump primer and it takes off and runs great without issue for the rest of the time. Stop again for a time and it is the same reutine. So I have pretty much figured it is a fuel deliver problem.
But here is my question. Does the onboard fuel tank have a "fuel pump" or a "lift pump"? Does the motor have a fuel pump on it so when it does this again I can disconnect the onboard tank and connect a pail of fuel to see what happens?
I am going to change out my black fual lines going the primer ball to clear line to see where the fuel runs out.
The boat has ran perfect since new (2000) and this has just started. I seems as if it is only when it is really hot out and we sit still for a time (15-60 mins).
