Keyswitch 9.9 - 4 stroke,'98-Evinrude wiring
Took off harness wires to key switch without marking them, [smart, heh?] put them back from memory [ smarter even], and luckily did not blow up anything, ....just won't crank even though I tested solenoid and starter motor separately and both are good individually. Motor starts/runs fair if rope pulled but no cranking possible even w/ a good battery. Would a shop manual have the answer here? Don't have a repair manual, can I get a used one? . This is a used 9.9 Evinrude 4 stroke electric 1998. model # E10FEXECM.
Wires to OMC key switch, I re-connected; obviously wrong now as: red to B, solid black to one of the marked M screws, purple wire to A, and black w/ yellow stripe to the down-screwed terminal also marked M; no wires on the C tab. Can anyone help with wiring connecting information or a used manual I could buy? Thanks in advance, 'Slowpoker'.
