I have recently flipped my boat in the surf , motors running fine after major pickling job. Just have a slight problem when running motor will run fine then it drops rpm for about 8 to 10 seconds then starts to run fine again for about 6 seconds. it just keeps on doing so . When i first ran it, i ran about 5 miles with no problems then started doing the cutting out. Cleand o2 sensor and previously cleaned the screen on the fuel pump. How about water in fuel?
Ant sugesstions would be great.
Thanks
Thanks
