Michigan Wheel Apollo vs. Avenger?
ramster
Does anyone know the differance between these two props? both are 14x20 four blade. I have tried an Apollo with good results, then sold it to a friend. I am looking to go back to a four blade 20", I have looked at Stilletto, turbo's and Ron Hill props, best price is on the Avenger. Anyone tried these props? My boat is Glastron 195 SX 5.0
Texasmark
Re: Michigan Wheel Apollo vs. Avenger?
You could buy your prop from a dealer who sells after the test drive, or just get a MWC Ballistic and forget it.............big grin for all the Ballistic haters.
Mark
ramster
I finally got someone at Michigan Wheel, and the Avenger is the same blade as the Apollo, differance is, the Avenger has a rubber hub for Mercruiser, and the Apollo is an XHS type hub. I ended up getting a Stilletto 3 blade 21. should have it Mon. can't wait for testing!
