DavidHickey
- Jul 23, 2007
- 7
Good Morning,
I have a 1990 Johnson GT100 Outboard. I'm having a little bit of a problem, it seems to be really cold starting when it starts up If I rev the engine with the neutral idle ajuster lever it starts to run good but as soon as I lower the rpms and try to take off it sputters. Just does'nt seem to like to idle at a low speed. Once I take off it runs perfect with no problems until I hit a no wake zone and have to slow down to idle speed. It runs fine at first but after awhile at idle speed it starts running rough and when I go to take off it sputters and quits unless I stop and rev the engine up in neutral and warm it up. Any ideas on what could be going on? I posted once before with no responses but someone suggested that the thermostat could be stuck open causing the engine to cool down too much at idle speeds. Any help would be appreciated. IF that would be the problem how hard is it to replace a thermostat? I can't find much information on this.
Thanks in advance
David
Thanks in advance
David
