  #1
Old August 16th, 2007, 05:26 PM
belewsonmymind belewsonmymind is offline
Default 90 HP Mercury 4 Stroke Outboard Bogging at full throttle
I have a 2003 90 HP 4 stroke Mercury that bogs when I take the throttle beyond 3500 RPM. When this began, the primer bulb was collapsing at the time of the bogging. I took it to the shop and they replaced the anti-siphon valve. I took the boat out to test and it ran great at full throttle for about 15 minutes before it began to bog down again. The primer bulb does not collapse anymore. It defininitely seems like a fuel starvation problem. Someone told me it might be the fuel pump. Any ideas? I just want to get on the lake and pull a tube. Help!
  #2
Old August 16th, 2007, 06:27 PM
Bigjohn1's Avatar
Bigjohn1 Bigjohn1 is offline
Default Re: 90 HP Mercury 4 Stroke Outboard Bogging at full throttle
It could be a few things....this engine is prone to clogged carb jets depending on use levels, last year's winter layup procedure, the locale you live in, etc. Have the carbs ever been rebuilt since you have owned the outboard? What kind of care/maintenance have you given the motor?
  #3
Old August 17th, 2007, 10:28 AM
I've owned the boat since June. The carbs have not been rebuilt that I'm aware of. What would cause the carbs to clog? How can I avoid in the future? Thanks!
  #4
Old August 21st, 2007, 05:52 PM
Turns out that the fuel filter was put in upside down and causing the fuel restriction at full throttle. The mechanic told me that one of the cylinders was flooding at idle and when the engine was turned off, but he said that if I wasn't having trouble cranking that I shouldn't worry about it. He said it would likely cost over $750 to rebuild the carb. Do I risk breaking anything leaving this unresolved?
  #5
Old August 21st, 2007, 06:34 PM
Bigjohn1's Avatar
Your mechanic has me confused. What fuel filter was installed upside down? The little plastic factory filter under the cowel only goes on one way (its a press fit on the plastic mounting flangewith screw-on site bowl).
To get a CARB 3-star rating on your engine, Merc had to put very small jets in the carbs. There have been some issues with carbs plugging up but it seems to be confined to folks who rarely use the boat and/or who don't do proper lay-up procedure before tucking the boat away for winter.
You can avoid most carb problems on this engine by using Quickleen additive in your fuel about every other tankfull of gas.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury outboard wont run on full throttle Dlong Mercury & Mariner Outboards 2 June 17th, 2006 07:18 AM
225XL Mercury 4-stroke RPM drops after running @ full throttle edwardschnog Mercury & Mariner Outboards 4 January 2nd, 2004 06:18 AM
99 johnson 50 hp bogging down at full throttle jay s Johnson & Evinrude Outboards 7 October 29th, 2003 12:29 PM
mERCURY 2002 9.9 4 STROKE NO FULL THROTTLE jlyar Mercury & Mariner Outboards 5 March 4th, 2003 09:46 AM
85 hp bogging to half speed at full throttle? jigsoffroad Johnson & Evinrude Outboards 0 July 9th, 2002 04:48 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
