Just put the boat back on the water since being laid up over the winter.
Finnished the season with a few problems which I set about fixing over the
winter.
- Distributer bearings were shot - torn down and rebuilt...
- Top plug hole was threaded - new insert gone in...
- Bad missfire from splits in plug leads - replaced them all.
I also rebuilt the carbs with 0.0785 main jets as opposed to the 0.80 jets
that were fitted last season, floats checked and adjusted where necessary...
6 new plugs, dissy cap and bush fitted.
Rebuilt fuel pumps.
Now the problem, once on the loch I warmed her up the usual 10 mins whilst
parking the trailer etc.... Took the motor for a run and made the usual idle
needle adjustments till hole shot was spot on....
Once at WOT the engine leaps to 5400rpm and runs for 5 seconds fine then
what feels like a missfire brings the revs down to 4700??? then up to 5k
down to 4700 yet if I lay off the throttle and cruise at 4500 shes quite
happy....
I then do the same thing with my mate priming the bulb and the problem is
gone...like a fuel pump issue but it cant be that cause they have just been
rebuilt.....
I suspect that the 0.785 jets are just too lean and the 0.080's will sort it
but there surely isn't that much difference?
My tank is vented and clear, to be fair the male fuel fitting on my engine
is a little old and hasn't been checked for wear...
Could this be something else?
All help greatly appreciated....
Many Thanks
Stan
winter.
Rebuilt fuel pumps.
happy....
rebuilt.....
Many Thanks
Stan
